EXAIR’s updated Blowoff Guide helps you pick out the proper Air Nozzle and Safety Air Gun to get your job done right. Did you know that a single typical open pipe blowoff on your production line could be costing you more than USD $1,800 per year? Did you know that that same open pipe could be causing permanent hearing damage to your employees? Were you aware that the nozzle on a typical commercial air gun could be a hidden killer? If your answer to any of these questions was, ‘no’, then you should definitely get your copy of EXAIR’s new Blowoff Guide.
EXAIR
www.exair.com
Filed Under: Pneumatic equipment + components, Pneumatic Tips, INDUSTRIAL SAFETY SYSTEMS
