NOSHOK expands valve products and manufacturing capabilities
By hcentorbi | June 19, 2012
NOSHOK expanded its valve product offering and valve manufacturing capabilities. The valve portfolio features standard bore and large bore needle and manifold valves, including block and bleed valves in hard or soft seat/tip designs with ratings up to 10,000 psi. Our valve design is patented for its performance and increased pressure capabilities. They also offer new valves and valve options such as 3-valve double block and bleed needle valves and meter manifolds.
They have significantly reduced delivery times and enhanced inventory levels, while continuing to offer 3-year warranties. NOSHOK has stringent requirements to ensure the performance of its valves by 100% helium leak testing every valve to 1 X 10-4 ml/s before it leaves their factory.
NOSHOK offers zinc-nickel plating as standard on our carbon steel valves. Zinc nickel is an alloy which offers corrosion resistance and long-lasting durability. Other benefits of zinc-nickel plating include increased deposit hardness, extended wear resistance and longer service life. ZnNi plating is WEEE and RoHS compliant.
For more information, visit www.noshok.com.
Noshok
Mobile Hydraulic Tips
Mini machines draw ICUEE crowds
excavator1
Why do cylinders fail on an excavator?
AgfaPhoto
What makes a quality hydraulic component?
A look ahead with JARP Industries’ CEO, Kevin Kraft
