(New Berlin,WI) -J. W. Winco, Inc offers Nylon Plastic Adjustable Levers in expanded inch and metric sizes.
The lever’s handle is glass fiber reinforced thermoplastic with molded in metal inlay on the tapped or blind bore type, and the same thermoplastic with metal insert on the threaded stud type. The insert, screw, and spring on the steel version levers are made of steel with a black oxide finish. Stainless steel versions are also offered. Special bores, threads, and stud lengths are available upon request, and for certain minimum quantities, special colors are available.
Pulling the lever upward disengages its internal serrations, allowing it to be swiveled to the best clamping position. When the lever is released, the serrations reengage.
: Design World :
Filed Under: Fastening + joining • locks • latches • pins
