Together, Sulzer and Tamturbo are developing technologies and offerings for oil-free compressed air. The uniquely designed HSR high-speed turbocompressor is manufactured in Finland. Not a single drop of oil is present in the machine, making it truly oil-free.
The variable speed, direct-driven technology of the HSR turbocompressor delivers a wide turndown of flow from the gearless direct drive. Titanium impellers supported by active magnetic bearings make the HSR the most energy-efficient and environmentally friendly compressor on the market. And as if that were not enough, the machine can also recover up to 93% of its generated heat, which can then be utilized in the industrial process.
One key benefit of this outstanding technology is the minimal life cycle and maintenance cost. For most, if not all compressors, a life cycle of over 15 years normally equates to 3.6 times the investment cost of the machine, but with the HSR, the maintenance costs are hugely reduced. Why? Because parts that don’t touch don’t wear, and parts that don’t wear don’t fail.
Key benefits
No touching parts
No oil
Direct gearless drive
Active magnetic bearings
Titanium impellers
Extremely low maintenance costs
Variable speed
Wide turndown, up to 63%
Remote monitoring
Heat recovery
Small carbon footprint
8-54 m3/min @ 7bar
The HSR turbocompressor is a reliable and carefree solution for oil-free compressed air. To guarantee the most energy-efficient system possible, we analyze the data from your compressed air system (air consumption and pressure variation) and build, install, optimize, and operate a suitable system.
With the HSR, the right amount of compressed air is always available. It adjusts to the varying needs of your process as the compressor setup can be scaled to produce the amount of air you need. In addition, all HSR compressors are variable speed driven and therefore ideally respond to changing needs.
The HSR turbocompressor with 24/7 remote monitoring optimizes compressed air production and generates an uninterrupted supply of 100% oil-free air, at the lowest cost per unit. The customer can focus on the operational performance of the site instead.
Sulzer
www.sulzer.com
Filed Under: Bearing Tips
