CAS DataLoggers recently provided the oven temperature data logging solution for a supplier of raw materials used in the plastics rotary molding industry. This company offers a comprehensive technical support service to their customer base, and part of this service includes technical advice and assistance to maximize their customers’ production efficiency.
CAS DataLoggers provided the customer with a Grant OMK610 Oven Temperature Profile Data Logger along with a custom enhanced thermal barrier for effective heat absorption. Users connected 4 Type K thermocouples to the data logger to monitor the internal temperature of the molding tool when inside the curing oven. The thermocouples were wired to the inside of the mold tool to monitor the air temperature and crystallization point of the polymer material, which is 180oC (356oF). This process monitoring aids their customer’s QA processes and assists them in minimizing the curing time while ensuring that the product is not over-cured, preventing a significantly detrimental effect on product appearance and quality.
Designed for temperature and through process monitoring, the logger’s 6 temperature inputs accommodated a broad range of Type T and Type K thermocouple probes and supported high sample rates up to 8 samples a second, enabling fast process times. During production runs, the barrier’s all-stainless steel construction formed a robust barrier for the data logger. For extended logging, the thermal barrier could be used to up to 250oC (482oF) for up to 20 minutes depending upon the size and volume of the product being molded.
With each reading, the Grant data logger reported and stored the time and date onto non-volatile memory holding up to 260,000 readings of secure data. Being battery-operated and portable, the oven logger utilized stand-alone operation. Users navigated the menus through the intuitive 3-button design via the integrated display, and these were also navigable via PC. Configuration enabled the logger to start and stop recording automatically at user-set times and temperature levels to present the most accurate process overview.
Passing through the process along with the products, the logger created a temperature profile which gave users a detailed view of their heat treatment process. For example, percentage cure results were shown onscreen at the end of every run and were available for storage and later analysis. Users also printed graphical reports of each run via USB without having to use a PC.
The customer can now optimize their process by reducing production cycle times while maintaining their high quality of production. This increase in yield assists them to reduce their manufacturing costs. In addition, using the included software, they are now able to document batch-to-batch thermal processing and print reports to validate that the product has been produced in accordance with their QA and product procedures. The kit was also cost-effective for this application, including the thermal barrier at a price similar to competing models.
CAS DataLoggers, Inc.
www.DataLoggerInc.com
