Oxygen Clean Series Manifolds from Clippard
By Design World Staff | May 7, 2008
Cincinnati, Ohio
— Single and multi-station manifolds are now available for use with Clippard’s all-new Oxygen Clean series electronic valves. These manifolds offer either single- or double-sided mounting in Oxygen-compatible electroless nickel plated brass material, and feature 1/8″ NPT input ports and #10-32 outlets.
The Oxygen series pneumatic valves utilize a unique patented valve system that has been used and proven throughout many industries. With a low power consumption of only 0.67 watts, a response time of 5 to10 milliseconds, and voltages of 6, 12, or 24 volt DC, these new valves offer unlimited flexibility in design.
All Clippard Oxygen clean products are manufactured and assembled for applications in Oxygen-enriched environments that are extremely sensitive to contamination. They are ultrasonically cleaned and inspected in an enclosed controlled area with a state-of-the-art positive pressure High Efficiency Particulate Air (HEPA) filtration system. In addition, both organic and inorganic contaminants such as particulate matter and Hydrocarbon oils are removed.
www.clippard.com
Filed Under: Pneumatic equipment + components, Valves, ELECTRONICS • ELECTRICAL
