    • On the Floor
VWDIR14 AC Parallel Shaft Gearmotors from Bison
By Design World Staff | October 13, 2008
Bison Gear & Engineering Corp. introduces its new VWDIR14 AC parallel shaft gearmotors which are designed not only as Von Weise Drop-In Replacements, but also to be compatible with most globally available AC power sources. Utilizing 1/20 HP (37.3W) AC motors which can be conveniently operated from either 115V or 230V, 60Hz or 50Hz power sources, the new gearmotors are available in 6 standard, off-the-shelf models. With gear ratios from 10:1 to 494:1, they offer corresponding output speeds from 181 to 4 RPM, and continuous torque ratings up to 50 in-lbs (5.65 N-m). The totally enclosed non ventilated (TENV) permanent split capacitor (PSC) AC motors and integral gear reducers are reversible and feature all-position face mounting with a 50 pound (22.7 kg.) overhung load capability.
The new VWDIR14 AC parallel shaft gearmotors are available with U.L. and CSA recognition as standard, and CE recognition can be provided for OEMs. In that regard, Bison Gear’s Innopreneurial(TM) application and design engineering capabilities to customize standard models to meet specific OEM needs are readily available. Customers’ shortened supply chain requirements are fulfilled by the units being manufactured in Bison Gear’s St. Charles, Illinois facilities to the highest quality standards to ensure dependable, long-life operation.
The VWDIR14 AC gearmotors are one more addition to Bison Gear’s rapidly expanding line of Von Weise Drop-In Replacement gearmotors, which is now made up of more than 80 standard models of AC and DC parallel shaft and right angle gearmotors.
www.bisongear.com
Filed Under: Motion control • motor controls, Motors (gearmotors)
Tagged With: bisongear
    • On the Floor
