WICKLIFFE, OH ‚– Parker announces the release of its new F42 Series of phosphate-ester compatible hydraulic hoses specially engineered to withstand pressures as high as 6,000 psi. Specifically designed to meet the high-pressure needs of the next generation of aviation ground support equipment, Parker‚’s F42 hose is versatile enough for other applications using phosphate-ester fluids. With a temperature range of -40‚°C to +80‚°C, and hose I.D. sizes from 1/2 to 1 1/4-in., additional applications include steel mills, aluminum mills and turbine test stands.
With the addition of the no-skive F42 series, Parker now offers the most complete range of phosphate-ester compatible hoses in the industry. Its hose line now includes five hoses (F42, 804, 424, 304 and 774), which together provide the widest size range (1/4‚†through 2‚â€) and support pressures from zero to 6,000 psi. The F42 line is approved to work with both 70 and 79 Series Parkrimp fittings available in more than 20 end configurations.
Filed Under: Hydraulic equipment + components
