PEM® Self-clinching Fasteners
By Design World Staff | November 18, 2009
PEM® self-clinching fasteners for use in stainless steel sheets provide ideal solutions to satisfy stainless assembly applications and promote lighter and stronger designs. These specially hardened stainless fasteners in various types and styles install permanently in thin stainless sheets and some provide the added benefit of excellent corrosion resistance to protect against corrosive conditions often encountered with medical devices and chemical and food processing equipment, among others.
The PEM stainless self-clinching product line includes panel fasteners integrating captive screws for “tool only” access to stainless assemblies; thru-hole threaded and blind threaded standoffs for stacking or spacing components to or from stainless steel panels; non-locking and self-locking floating nuts to accommodate mating hole misalignment; fasteners for flush-mount attachment applications enabling permanent joining of two sheets without protrusions; flush-head studs; pins; and nuts.
Depending on type, the fasteners are produced from precipitation hardening grade stainless, 300 Series stainless, 400 Series stainless, or A286 stainless steels and most are designed to install in stainless sheets as thin as .030”/0.8mm. With the fastener harder than the host stainless sheet, successful clinching results in their becoming integral parts of an assembly without risk of loose hardware.
PennEngineering
www.pemnet.com
Filed Under: Fastening + joining • locks • latches • pins
C2 lever latch offers auto-relock functionality and modern appearance
Covered compression latch enhances safety and reduces maintenance errors
Omron D41L hygienic guard locking switch is a tamper-proof solution for ensuring access control and workplace safety
Omron D41G guard lock and handle is an easy-to-wire and intuitive solution for safeguarding machine tools and robotic cells
