PEM® Type FHP™ self-clinching flush-head studs for use in thin stainless sheets serve as ideal solutions for attachment applications where demanding requirements for corrosion resistance and thinner, lighter designs must be satisfied. They provide practical alternatives to weld studs by enabling easier installation at lower costs.
PEM Type FHP flush-head studs exhibit high hardness and provide high corrosion resistance to perform in the most challenging industry applications, including medical, foodservice, and marine, among others.
These studs are formed from A286 stainless steel for use in sheet hardness of 92 or less on the Rockwell “B” scale. They mount flush and permanently in stainless sheets as thin as .040”/1mm and greater and will become integral parts of an assembly. Only a mating nut is required for final component attachment.
PEM Type FHP flush-head clinch studs are available in thread sizes #4-40 through #10-32 and M3 through M5 and in a range of 10 lengths.
: Desing World :
Filed Under: Fastening + joining • locks • latches • pins
