Pneumatic Swing Clamp
By Design World Staff | February 15, 2007
Gainesville, FL — Fabco-Air, Inc. announced a new clamp arm that rotates 90° as it extends up away from the work piece providing clearance and access for loading and unloading. Double acting operation and a standard magnetic piston, combined with a variety of optional magnetic sensors, enable positive cycles and work piece detection features.
Other standard, no-charge features include a rugged clamp arm with adjusting clamp bolt and four wrench flats on the piston rod for easy clamp arm positioning. Clamp arm rotation is available clockwise or counterclockwise. Offered in 8 bores from 12 to 63mm and strokes from 10 to 50mm, the units have extruded aluminum bodies with 8 linear keyhole slots for external mounting or round profile sensors. Ports can be NPT or BSP taper. Counter bored thru holes enable rigid mounting to automation equipment surfaces in a minimum of space.
For more information contact:
Fabco-Air, Inc.
3716 N.E. 49th Avenue, Gainesville, FL 32609-1699
• Phone (352) 373-3578      • Fax (352) 375-8024
• Website: www.fabco-air.com  • E-Mail: [email protected]
:: Design World ::
Filed Under: Clamps, Fluid power
Next steps in fluid power connections
cylinder
Small, compact cylinder boasts large preload capacity
Clippard Eclipse proportional Valve
Proportional isolation valve offers ultra fine resolution and high repeatability
Fluid power manufacturer receives environmental stewardship recognition
