Power Analyzers from Carlo Gavazzi
By Design World Staff | March 26, 2008
Buffalo Grove, IL – The new EM26-96 Series Compact Power Analyzers from Carlo Gavazzi are the newest addition to our extensive Energy Management product portfolio. This innovative product supplies a very effective and easy-to-use instrument that provides both utility metering and electrical parameters analysis and control – harmonics included. MID compliance, three digital outputs and RS485 communication port, harmonic analysis up to the 15th harmonic, dual color backlit LCD display. The display is also innovative in that the backlit LCD display’s color automatically changes in case of alarm.
The meters are designed to assure high profile solutions to all industries that require cost allocation and parameter control services. Some other technical features include:
    •Class B according to EN50470-1-3, Class 2 (kvarh) according to EN62053-23
    •Accuracy ±0.5 RDG (current/voltage)
    •Harmonic analysis (FFT) up to 15th harmonic (current/voltage)
    •Gas, cold water, hot water, kWh remote heating measurements
    •3 digital inputs for tariff selection, DMD synch or gas/water (hot-cold) and remote heating
    metering (on request)
    •3 digital outputs for pulses or for alarms or as a mix of them (on request)
    •RS485 serial output (on request)
    •Universal power supply: 18 to 60VAC/DC, 90 to 260AC/VDC
    •Dual color backlight: no backlight, blue or white (selectable)
    •96x96mm front panel with IP50 protection
    •MID (Measuring Instruments Directive) “annex MI-003” compliant
www.GavazziOnline.com
Filed Under: Electronics • electrical, Washers • spacers
molex-premo-flex
