Infineon’s OptiMOS™ 5 25V and 30V product family of next-generation of Power MOSFETs in standard discrete packages feature a new class of power stages named Power Block, and in an integrated power stage, DrMOS 5×5.
Megatrends such as cloud computing, IoT and social media drive an increasing demand for computing power. This is accompanied by a boost in energy consumption which, in return, triggers the need for energy efficiency within the power conversion chain. The recently introduced OptiMOS 5 family offers benchmark solutions with efficiency improvements of around 1 percent across the whole load range compared to its previous generation, exceeding 95 percent peak efficiency in a typical server voltage regulator design. This improved performance is based for example on the reduction of switching losses (Q switch) by 50 percent compared to the previous OptiMOS technology. Implementing the new OptiMOS 5 25V can lead to energy savings of 26.3kWh per year for a single 130W server CPU working 365 days. Adding 50,000 servers working in a server farm on average this would amount to savings of 2.6 GWh per year.
New Packaging Technology
The launch of the OptiMOS 5 25V and 30V product family is accompanied by the introduction of a new packaging technology offering a further reduction in PCB area consumption. It is used in the Power Block product family and in the integrated powerstage DrMOS 5×5 and offers a source down low-side MOSFET for improved thermal performance, with a reduction by 50 percent of the thermal resistance in comparison to standard package solution, such as SuperSO8.
Infineon`s Power Block is a leadless SMD package comprising the low-side and high-side MOSFET of a synchronous DC/DC converter into a 5.0×6.0mm 2 package outline. With Power Block, customers can shrink their designs up to 85 percent by replacing two separate discrete packages, such as SuperSO8 or SO-8. Both, the small package outline and the interconnection of the two MOSFETs within the package minimize the loop inductance for best system performance.
OptiMOS 5 25V is also used in an integrated power stage, combining DrMOS 5×5, driver and two MOSFETs, for a total area consumption on the PCB equal to 25mm². The integrated driver plus MOSFETs solution results in a shorter design time and is easy to design-in. Additionally, the dovetailed power stage includes a high accurate temperature sense of +/-5°C (compared to +/-10°C of an external one) which enables higher system reliability and performance.
www.infineon.com
The post Power MOSFETs drive server energy efficiency appeared first on Analog IC Tips.
Filed Under: Analog IC Tips
