The Eaton 9135 UPS (uninterruptible power system) meets the demanding needs of mission-critical computer networks and facilities‚’ digital operations. The new 5 and 6 kVA UPSs are easy to use to safeguard systems against damage and power disturbances and outages.
The models operate at up to 97% efficiency in its high efficiency mode and up to 91% in double conversion ‚– using less energy and dissipating less heat.
The 9135 also provides hot-swappable battery and control modules that let you quickly remove and replace power components without powering down the UPS or interrupting power to the connected equipment. Set-up is handled through the intuitive LCD screen, which can also be used to monitor conditions and troubleshoot problems.
Features include:
‚— A wide input voltage window that eliminates the need to depend on batteries to correct power
fluctuations.
‚— Extended battery runtime options to power essential systems for more than an hour during an outage.
‚— Four output receptacles and rear panel communication options for remote connectivity options.
Eaton Corp.
www.eaton.com/powerware
Filed Under: CONNECTIVITY • fieldbuses • networks • gateways, Power supplies
