Raptor SS precision planetary gearhead from CGI is washdown-ready
By Lisa Eitel | February 27, 2017
The Raptor SS precision planetary gearhead from CGI Inc. offers stainless-steel construction and IP65-rated sealing for a washdown-ready design that is suitable in food and beverage and other sanitary applications.
The planetary gearhead also has high stiffness to withstand high loading — as well as high-torque gear geometry.
Components are made of advanced materials that get specialty heat treatment for durability. There are also versions of the planetary gearhead that come with a white epoxy coating and optional food-grade grease for food-related applications.
The Raptor SS has features that simplify installation; it can mount in any direction and has a captive input pinion. NEMA and metric configurations are standard.
Maximum input speed for the planetary gearhead is 6,500 rpm. Service life exceeds 15,000 hours. Maximum backlash (arc-min) is 4 (for the one-stage design), 6 (for the two-stage design), and 8 (for the three-stage design).
• Efficiency for the one-stage design stage is better than 95%
• Efficiency for the two-stage design stage is better than 90%
• Efficiency for the three-stage design stage is better than 85%
Raptor SS planetary gearhead — 023RTX (NEMA) / 060RTX (METRIC)
TNOM (1) TMAX ACCEL TE-STOP (2)
Ratio In-lbs (Nm) In-lbs (Nm) In-lbs (Nm)
4:1 395 (45) 468 (53) 947 (107)
5:1 340 (38) 400 (45) 926 (105)
7:1 231 (26) 280 (32) 861 (97)
10:1 150 (17) 190 (22) 720 (81)
16:1 395 (45) 468 (53) 947 (107)
20:1 395 (45) 468 (53) 947 (107)
25:1 340 (38) 400 (45) 926 (105)
28:1 395 (45) 468 (53) 947 (107)
35:1 340 (38) 400 (45) 926 (105)
40:1 395 (45) 468 (53) 947 (107)
50:1 340 (38) 400 (45) 926 (105)
70:1 265 (30) 320 (36) 861 (97)
100:1 175 (20) 221 (25) 720 (81)
160:1 395 (45) 468 (53) 947 (107)
280:1 395 (45) 468 (53) 947 (107)
400:1 395 (45) 468 (53) 947 (107)
500:1 340 (38) 400 (45) 926 (105)
700:1 265 (30) 320 (36) 861 (97)
Raptor SS planetary gearhead — 034RTX (NEMA) / 090RTX (METRIC)
4:1 1452 (164) 1829 (207) 3473 (392)
5:1 1274 (144) 1605 (181) 3316 (375)
7:1 863 (98) 1088 (123) 2821 (319)
10:1 559 (63) 704 (80) 2456 (277)
16:1 1452 (164) 1829 (207) 3473 (392)
20:1 1452 (164) 1829 (207) 3473 (392)
25:1 1274 (144) 1605 (181) 3316 (375)
28:1 1452 (164) 1829 (207) 3473 (392)
35:1 1274 (144) 1605 (181) 3316 (375)
40:1 1452 (164) 1829 (207) 3473 (392)
50:1 1274 (144) 1605 (181) 3316 (375)
70:1 993 (112) 1251 (141) 2821 (319)
100:1 642 (73) 810 (92) 2456 (277)
160:1 1452 (164) 1829 (207) 3473 (392)
280:1 1452 (164) 1829 (207) 3473 (392)
400:1 1452 (164) 1829 (207) 3473 (392)
500:1 1274 (144) 1605 (181) 3316 (375)
700:1 993 (112) 1251 (141) 2821 (319)
Originally posted on Motion Control Tips.
Lisa Eitel
