Rigid couplings join variety of unsupported shafts
By Leslie Langnau | December 5, 2012
Coupling Tips
Line of rigid shaft couplings come in a range of types, sizes, and materials for joining unsupported shafts in applications ranging from delicate instruments to large mixers and pumps.
Stafford Rigid Shaft Couplings come in one-, two-, and three-piece designs, with or without keyways, in sizes ranging from 1/8 in. to 4 in. I.D. Featuring multiple clamping screws for  holding power, these rigid couplings securely join all types of unsupported shafts, and are easy to remove for periodic maintenance and repair.
Machined from stainless steel, steel, and aluminum, the couplings have a smooth bore to protect shafts and thin-wall tubing. For high torque applications, they can incorporate keyways and accommodate different size shafts, stepped bore sizes are offered in inch and metric dimensions. Heavy-duty and remachinable couplings are also available.
Stafford Manufacturing Corp.
www.staffordmfg.com
Filed Under: Couplings
Tagged With: Stafford Manufacturing Corp.
lmounts.com
Limit-switch mounts are highly adjustable
IMG_1453
Coupling bolts help with live tooling in lathe applications
Bibby-RFK212-BK-Grid-Coupling-Front
Grid coupling helps keep the water on at pumping station
Coupling cleans up challenges for construction sweepers
