The Rino P20 and P30 low backlash right angle gearboxes have a backlash of 8 arc-minutes or less. Torques to 36 inch-lbs at 2000 rpm input. Higher torques at lower input rpm. Available with shaft input, NEMA 17 flanges or custom flanges for your motor. P20 size without flange is 1.6‚†x 1.9‚†x 0.9‚†and the P30 is 2.4‚†x 2.8 x 1.1‚â€.
Ratios from 5:1 to 120:1 are standard. All types of customizing are easily done. The photo shows shaft input and NEMA 17 versions.
The P20 and P30 series have a single piece stainless worm and input shaft, machined aluminum block housing, dual ball bearings for shaft supports, output bore with optional stainless output shaft. They are designed for 24/7 operation.
Applications include: positioning applications for cameras and inspection devices, food machinery, semiconductor processing, packaging machinery, medical diagnostic equipment, and all sorts of usual and unusual applications.
www.rinomechanical.com/LBG
Filed Under: Gears • gearheads • speed reducers, Motion control • motor controls, Motors (gearmotors)
