Rotary Sensors for Extreme Environments
By Design World Staff | December 28, 2010
The IPX series of rotary position sensors have unlimited mechanical movement. The sensor is sealed to IP69 K and has a 79 mm diameter housing size. Repeatability is to 0.002% over measurement ranges up to 350°. The TX2 series has fully redundant 2nd channel versions and an operating life of more than 100 million movements. Combining stainless steel shaft and anodized aluminum housing construction with the IP rating makes the IPX saltwater resistant and splash proof. The TX2 series operates under temperature conditions from -40 to +120° C as well as in the presence of high humidity, dust, shock and vibration.
Novotechnik
www.novotechnik.com
Filed Under: Factory automation, Sensors (position + other), Sensors (proximity), Test + measurement • test equipment
Solid-state relay characteristics and applications
