MIDDLETOWN, PA – Phoenix Contact’s screw-connection terminal blocks are now available with an integrated PE grounding foot. The integrated PE foot is available in 6.2 mm versions of the UT 4 knife disconnect, diode and fuse terminal blocks.
The UT 4-PE series saves space while providing a reliable termination for grounding the shields commonly used in shielded twisted-pair wires for analog and digital sensors. The functional blocks also provide options to disconnect (HEDI) or use a universal lever-style fuse holder (HESI) for 5×20 plugs with or without light indication.
A compact design with uniform dual-bridge channel delivers power distribution quickly and effectively with robust FBS push-in jumpers. The UT series is part of Phoenix Contact’s CLIPLINE Complete system, which features standardized push-in bridging, marking and testing accessories for all connection technologies.
Phoenix Contact
www.phoenixcontact.com
Filed Under: Terminal blocks, ELECTRONICS • ELECTRICAL
