SIL 3-rated Relay Designed for Process Safety
By Design World Staff | October 28, 2010
MIDDLETOWN, PA – The PSR-FSP process safety relay from Phoenix Contact is a safe coupling relay specifically designed to operate with fail-safe controls in process applications. This process safety relay can be used in applications up to a Safety Integrity Level (SIL) 3 requirement, according to IEC 61508.
PSR-FSP-process-safety-relay-Phoenix-Contact
The process safety relay meets the requirements of fail-safe control. The PSR-FSP is compatible with “test pulses” that occur on safe PLC/DCS outputs. Inrush requirement is limited for safe PLC/DCS output compatibility, and it has a built-in fuse for the safe output contact.
This SIL-rated relay is just 17.5 mm wide. It features a normally open (NO) redundant safety output and a normally closed status contact that can be externally connected. The maximum switched current of the NO contact is 5 A. The device also has an externally accessible 5 x 20 mm standard fuse to protect the load contact. Pluggable and coded screw or spring-cage terminals simplify the wiring.
Phoenix Contact
www.phoenixcon.com
Filed Under: Electronics • electrical, Relays, Safety systems + components
molex-premo-flex
