Slim 30W Power Supply
By Design World Staff | May 6, 2011
Compact 30W DIN-rail power supply is 50% smaller than the existing model–22.5 mm wide–and is rated 1.3A @ 24 Vdc with an adjustable output voltage. The unit has a universal wide input voltage of 85 – 264 Vac and delivers the full 30 W output power over the temperature range of –10° C to +60° C. This supply has the highest efficiency in its class with up to 89.4% with less than 0.4 W no load losses. Spring clamp terminals were replaced with large screw terminals for larger wire sizes. These terminals will accept a wire up to 10 AWG or two smaller wires on each connection point.
PULS Power Supplies
www.pulspower.us
Filed Under: Electronics • electrical, Power supplies
molex-premo-flex
