SMT “Auto Blade” Fuse Clips Hold Firmly
By atesmeh | October 28, 2011
Keystone Electronics Corp. offers wide selection of surface mount, automotive blade fuse clips engineered to secure fuses in place even after multiple insertions. Suitable for high-density applications, these new, compact, low profile clips are available in vertical, horizontal and thru-board blade entry types. They accept standard style ATO and ATC Fuses; low profile Mini #891 or ATM-LP Fuses; as well as Mini and ATM Series of Mini Auto Fuses. The voltage rating is at 500 VAC and 15 A to 30 A. The new entries are made of Brass with Tin Nickel plate and are available in bulk or in tape and reel. For vertical entry clips used with Mini, low profile or standard Auto Blade Fuses, catalog No. 3586 (bulk) or 3586 TR (tape & reel) are appropriate. To suit horizontal clips used with Mini Auto Blade Fuses, catalog No. 3569 (bulk) or 3569 TR (tape & reel) are available. Cat. No. 3563 (bulk) or 3563 TR (tape & reel) are appropriate for low profile environment vertical entry clips using Mini Auto Fuses.
800-221-5510, www.keyelco.com
