Solderless LED Socket for Bridgelux RS LEDs
By Dave Miyares | May 16, 2011
TE Connectivity (TE) announces a new addition to its line of solderless LED sockets: the RoHS-compliant Type BR socket for quick termination of Bridgelux RS LEDs. This new offering eliminates the need to design, manufacture and integrate a complex metal clad printed circuit board assembly into a lighting fixture. Additionally, it provides lighting designers with a broad range of LED mounting options as it can be easily positioned and assembled anywhere in a fixture using simple hand tools.
This one-piece connector assembly features TE’s poke-in wire termination method for 18 through 22 AWG solid wires, 18 through 20 AWG pre-bonded wires and 18 AWG stranded wires. Included standoff posts properly position the solderless LED socket assembly onto the heat sink and only four M3 or #4 screws are required to secure and complete the assembly. The LED is retained in the socket housing with a slight press fit prior to mounting the assembly into the light fixture.
For enhanced integration capabilities, the socket design accepts the commercially-available LEDIL Britney series of optics. Alternatively, ample space is available for use with other custom optical solutions.
TE-Connectivity-Solderless-LED-Socket-for-Bridgelux-RS-LED
Additional product features include:
• a cleared area designated for reflector mounting that accepts custom or commercially-available optics,
• integral wire strain reliefs to prevent inadvertent wire pull out after assembly, and
• UV-resistant housing material for outdoor use to prevent housing discoloration.
The socket is UL-recognized to UL 1977 for use in UL 8750 applications.
TE Connectivity
www.te.com/lighting
Filed Under: Connectors (electrical) • crimp technologies, Electronics • electrical, Lights • signal lamps • indicators
molex-premo-flex
