Stainless steel multiple-joint hinges available from JW Winco
By Mike Santora | September 26, 2018
JW-Winco-Stainless-Steel-Multiple-Joint-HingesJW Winco, Inc., A Ganter Company, a supplier of standard industrial machine components, now offers GN 7237 Stainless Steel Multiple-Joint Hinges with Internal Mounting Brackets and an Opening Angle of 180°. JW Winco’s GN 7237 Stainless Steel Multiple-Joint Hinges are installed on the inside of flaps, hatches, or compartment doors to save space and ensure protection against vandalism. The hinges have a maximum opening angle of 180°, which provides optimal accessibility for hatch doors, for example.
“Use of this hinge type leaves housing exteriors free of attachments that do not match the design or that should be avoided entirely in the interests of fast and easy cleaning,” said John M. Winkler, CEO, Office of the President at JW Winco.
Stainless steel multiple-joint hinges are generally used in pairs, meaning that one type L (Left-Hand) and one type R (Right-Hand) are used per opening. For higher loads, such as from large hatches, these can be supplemented with additional hinges of either type.
The Stainless Steel Multiple-Joint Hinges are manufactured in a way that includes the angled mounting brackets, which are mounted on the housing or the door, and an intervening seven-speed, clearance-free, self-lubricated joint mechanism. Due to the movement of the joint mechanism, when opening, for example, a flap is first slightly lifted and then swung by 180°.
JW Winco is a manufacturer/distributor of inch and metric standard parts. JW Winco offers an extensive selection of plastic, steel and stainless steel adjustable levers, cabinet U-handles, hinges and locking mechanisms, revolving and retractable handles, hand wheels, hand cranks, tube connection and conveyor components, construction tubing, shock absorption mounts, leveling mounts, hand knobs, spring, ball and indexing plungers, jig, fixture and fastening components, retaining magnet assemblies, toggle clamps, casters and wheels, universal joints, oil sight glasses, and metric tools for the industrial and commercial equipment industries.
JW Winco
www.jwwinco.com
Filed Under: ALL INDUSTRY NEWS • PROFILES • COMMENTARIES, Fastening + joining • locks • latches • pins, Flanges • supports • mounts • brackets
Tagged With: jwwinco
Covered compression latch enhances safety and reduces maintenance errors
Omron D41L hygienic guard locking switch is a tamper-proof solution for ensuring access control and workplace safety
Omron D41G guard lock and handle is an easy-to-wire and intuitive solution for safeguarding machine tools and robotic cells
Omron D41D high-coded non-contact door switch for safeguarding machine tools and robotic cells
