Steel-Disk Seals
By Design World Staff | March 1, 2007
NILOS steel-disk seals for grease-lubricated roller bearings contribute to bearing service life.  They protect against contaminants in mining equipment exposed to dirt, dust, and debris and minimize bearing friction loss and heat build-up.  They also prevent lubricants from leaking.
Their non-contact, grease-filled labyrinth sealing elements comprise laminated steel-seal disks and steel cores.  The seals resist axial pressure and do not slip when secured in the axial direction on the inner and outer edge of a roller-bearing ring.  They come in a range of shaft and casing diameters and are ready to install for quick and easy mounting.
SKF Linear Motion & Precision Technologies
www.linearmotion.skf.com
:: Design World ::
Filed Under: Machine tool industry + subtractive manufacturing, Fastening + joining • locks • latches • pins, Seals
Covered compression latch enhances safety and reduces maintenance errors
Omron D41L hygienic guard locking switch is a tamper-proof solution for ensuring access control and workplace safety
Omron D41G guard lock and handle is an easy-to-wire and intuitive solution for safeguarding machine tools and robotic cells
Omron D41D high-coded non-contact door switch for safeguarding machine tools and robotic cells
