Stream Vac in line air conveyor from Nex Flow
By Editor | March 25, 2015
The versatile and affordable compact air cleaning system is ideal for the removal of fumes, dust and other air pollution from work stations without the need for heavy and bulky machinery. The Nex FlowTM Stream Vac TM is an in line air conveyor that, when hooked up to a 2” hose and connected to a compressed air line, it will remove up to several hundred cubic feet of air while using only a minimal amount of compressed air, taking with it welding fumes, soldering fumes, particulate from local grinding operations, smoke and particulate from almost any “spot” application. Three different attachments provided for various applications – round nozzle, rectangular nozzle and tapered oval.
fume-extractor
A safe and improved healthy condition in the workplace improves employee morale, increases worker productivity, decreases absenteeism and even reduces insurance costs in many cases. A cleaner environment can enhance the performance of machinery even cut maintenance costs. However, until now there was no low cost solution to enhance the environment.
This low cost, compact and portable unit operates utilizing a minimal amount of compressed air. It comes with a magnetic stand to “plug into position” on any magnet accepting metal surface. Simply connect the snap – on collection attachments and clamp a 2” hose on the opposite side, hook up your compressed air and you are set to go. Comes complete with shut-off valve.
Nex Flow
www.nexflow.com
Filed Under: Pneumatic equipment + components
Tagged With: nexflowair
5 ways to improve packaging machinery with smart pneumatics
Clippard-Cordis-CFC-electronic-Flow-Controller
Cordis flow controller offers high resolution and repeatability in a closed-loop system
Upgrading equipment with solenoids
Clippard Eclipse proportional Valve
Proportional isolation valve offers ultra fine resolution and high repeatability
