Submersible Level Sensors
By Design World Staff | April 21, 2008
LOGAN, UT — PT-500 Submersible Liquid Level/Pressure Transmitters from Automation Products Group, Inc. are now CSA certified for use in Class I, Div. 1, Groups C and D, and Class I, Zone 0, Group IIB hazardous locations. Class I, Div. 1, Group C, and Class I, Zone 0, Group IIB atmospheres contain ethyl-ether vapors, ethylene, or cyclopropane. Class I, Div. 1, Group D atmospheres contain gasoline, hexane, naptha, benzene, butane, propane, alcohol, acetone, benzol, lacquer solvent vapors or natural gas.
The PT-500 features a vented, watertight cable and delivers a high precision 4-20mA solid-state signal while submerged up to 450 ft. A unique (patent pending) removable stainless steel cage connects to the sensor with a simple snap ring and enables users to save significantly on sensor replacement costs.
Rugged IP68 protected PT-500 transmitters deliver accuracy of 0.50% of span, and are temperature compensated to ensure accuracy and long-term stability under extreme temperature variations. Simple-to-install surface mount technology provides added protection from shock and vibration.
www.apgsensors.com
Filed Under: SENSORS, ELECTRONICS • ELECTRICAL
