The Model 151DT01 Control
By Design World Staff | June 11, 2008
The Model 151DT01 is a large thumbwheel control designed to give better tactile ‚“feel‚” as well as easier control.  A micro-pushbutton, Model 145MA, is a Hall Effect device with linear analog output.  Both components can integrate into an industrial joystick knob or control panel.
Model 151DT01 has an 8.2 mm-wide thumbwheel and compact mounting dimensions of 37 x 25.25  x 27.7 mm.  With an IP67 DIN EN 60529 protection class housing and operating temperature range from -25 to +75‚° C (-13 to +167‚° F), this unit suits harsh environments and continuous outdoor use.  Operating voltage is 4.5 to 5.5 Vdc standard, with 15 mA current and output voltage of 0.5 to 4.5 Vdc.
Elobau
www.elobau-st.com
Filed Under: Switches, ELECTRONICS • ELECTRICAL
