WAGO Corporation's Interface Adapter provides JUMPFLEX® Signal Conditioners and Relays with a tool-free interface to the WAGO-I/O-SYSTEM or other PLC interfaces. Interface Adapters capture analog/digital signals for eight combined JUMPFLEX® modules – ideal for machines requiring large amounts of input/output signals. Ribbon cable and D-Sub connector models provide 8-channel connectivity; other interface products connect the Interface Adapters to WAGO's 16-Channel Digital I/O modules.
JUMPFLEX® Interface Adapters streamline commissioning and eliminate wiring errors for both field and control levels. To simplify troubleshooting, each Interface Adapter features marking tag holders and a test location at each channel. Integrated indicators for signal and/or power status are also included. Complementary products include DIN-rail mount interface boards and relay modules.
About JUMPFLEX® Signal Conditioners and Relays:
JUMPFLEX® Signal Conditioners and Relays feature an ultra-compact 6mm, DIN-rail mount housing and a flexible jumpering system that eliminates redundant wiring. All models provide safe isolation of input, output and supply circuits with 2.5 kV test voltage to EN 61140. Signal transmission is attained with an accuracy <0.1% of the full scale value. The Signal Conditioner modules are rated -25 to +70°C for wide variety of industrial sensors.
WAGO Corp.
www.wago.us
Filed Under: Electronics • electrical, I/O modules, Relays
