    • Subscribe!
Windjammer Brushless DC Blowers
By Design World Staff | October 24, 2008
Windjammer‚® variable-speed, brushless DC blowers offer compact, low noise, and long life solutions ideally suited for medical and industrial applications. The extensive standard product line includes low voltage and high voltage versions, as well as bypass and thru-flow products to satisfy the widest range of blower application requirements.
Low voltage Windjammer blowers provide output pressure up to 98 in. H2O and flows up to 160 CFM. Output pressure for high voltage blowers can be realized up to 169 in. H2O and flows up to 274 CFM, depending on model.
All Windjammer brushless blowers feature compact design with diameters of 5.7 in. (145mm). Their engineering promotes long life and virtually maintenance-free operation.
Speed can be adjusted internally with an onboard potentiometer or with an external PWM or DC control that actively varies blower performance. Blowers accept voltage inputs of 24 VDC, 48 VDC, 72 VDC, 120 VAC or 240 VAC, depending on model. Internal electronics convert the line voltage AC input to DC.
Among options, an integrated IntelliGen‚â„¢ electronic control drive utilizing a factory-programmed digital signal processor (DSP) and custom option cards can be incorporated to meet specific application demands. Blowers can additionally be customized to satisfy particular application needs.
www.ametektechnicalproducts.com
Filed Under: Medical, Electronics • electrical
molex-premo-flex
    • Subscribe!
