Zinc Die Cast Adjustable Alignment Hinges with Cover Caps
By Patrick Curran | February 15, 2010
NEW BERLIN, WI — J.W. Winco, Inc. announced it now offers series GN 238 Zinc Die Cast Adjustable Alignment Hinges with Cover Caps.
JW-Winco-Adjust-Align-Hinges
These RoHS-compliant, metric sized hinges are designed to allow a technically and visually perfect alignment of the door to its frame. They are available with both sides adjustable (Type BJ), one side adjustable (Type EJ), and fixed hole type (Type NJ). The steel adjustable bushing has a serrated ring on its bottom side that seats into the radially positioned serrations of the zinc hinge plate when the countersunk screw is tightened. This secures the bushing in place. The plastic cover hides the adjustable bushing and screw to prevent dirt from entering, and also provides a clean, appealing look.
The hinge body is zinc die-cast with a black powder coated finish. The adjustable bushings are blackened steel. Hinge pin is stainless steel and hinge cover is dark gray plastic.
J.W. Winco
www.jwwinco.com
Filed Under: Die casting, Fastening + joining • locks • latches • pins
Covered compression latch enhances safety and reduces maintenance errors
Omron D41L hygienic guard locking switch is a tamper-proof solution for ensuring access control and workplace safety
Omron D41G guard lock and handle is an easy-to-wire and intuitive solution for safeguarding machine tools and robotic cells
Omron D41D high-coded non-contact door switch for safeguarding machine tools and robotic cells
