Zinc Die-Cast Door Locking Mechanisms
By Design World Staff | August 1, 2008
J. W. Winco, Inc. announces it now offers Zinc Die-Cast Door Locking Mechanisms.
Available in metric sizes, these locks are economical. They offer a straight-forward locking action, rather than a locking and clamping action. The choice of 22 differently-shaped catch plates provides a range of latching distances from 4 to 50 mm, or 0.157 to 1.97 inches. Locks with key operation are supplied with two keys, which can be removed from the lock in both open and locked positions. In the standard key lock versions, all locks can be operated with the identical key. Locks requiring different keys are available upon request.
The housing of the door locking mechanism is zinc die-cast with a chrome-plated finish. The lock hardware is made of steel and zinc-plated with a blue passivated finish. The hand knob is constructed of black glass-filled nylon plastic.
www.jwwinco.com
Filed Under: Fastening + joining • locks • latches • pins
Tagged With: jwwinco
Covered compression latch enhances safety and reduces maintenance errors
Omron D41L hygienic guard locking switch is a tamper-proof solution for ensuring access control and workplace safety
Omron D41G guard lock and handle is an easy-to-wire and intuitive solution for safeguarding machine tools and robotic cells
Omron D41D high-coded non-contact door switch for safeguarding machine tools and robotic cells
