Klüber Lubrication to Showcase New NSF H1-registered Lubricants
Klüber Lubrication will display its latest NSF H1-registered lubricants for the packaging and processing industry at PACK EXPO, Sept. 23-25 at the Las Vegas Convention Center. Klüber will exhibit at booth S7046 and have representatives available to discuss the company’s products, services and expertise with PACK EXPO attendees.
Products from Klüber provide efficient solutions for increasing productivity in extreme applications, such as ovens, freezers and high friction points in conveyors, proofers and palletizers.
Kluber will showcase the following products and services at PACK EXPO
Klüber will showcase the following products and services at PACK EXPO:
The ALLPLEX FMG Series of greases are multi-purpose, NSF H1 registered products for the food processing, beverage and pharmaceutical industries. ALLPLEX is specifically designed for use in applications where incidental food contact is possible. The special additive package provides for excellent anti-wear and extreme pressure protection from corrosion. Equipment in wash-down environments benefits from the aluminum complex thickener system, which provides excellent water resistance in addition to a broad temperature range. ALLPLEX is available in multiple standard packaging options from drums to cartridges, and can be used as a single point lubricator. Klüber has also included ALLPLEX with its innovative Klübermatic system, a single point lubricator option that improves process efficiencies, as well as safety in the workplace.
Klüberfood NH1 CH 2-220 is the premier oil for lubricating high-temperature chains in both baking and beverage can manufacturing applications. This fully synthetic, ester-based lubricant can operate at extreme temperatures for longer periods of time and without residue build-up, all while protecting chain components from increased wear. Users benefit from dramatically reduced consumption, cleaner operations, reduced noise and no smoking when applying oil. The can manufacturing environment presents significant challenges for proper lubrication of chains, including high temperatures, high and low speeds, potential ingredient contamination, increasing wear and more. Klüberfood NH1 CH 2-220 is an NSF H1-registered lubricant that not only keeps food safe from incidental contact, but solves each of the aforementioned challenges as well.
Spraying Systems
Klüber Lubrication, in collaboration with Spraying Systems Co., tested and qualified a solution for pin-chain applications for beverage can manufacturing. The combination of the AccuJet® Electrostatic Lube System with Klüberfood NH1 CH 2-220 provides complete and optimum lubrication of DECO oven pin-chains. As a result, users reduce oil consumption, increase chain life and, due to the elimination of oil mist, create a safer work environment for operators while decreasing chances of contamination.
Klüberfood NK1 Z 8-001 Spray is a cleaner and de-greasing spray for the food-processing and pharmaceutical industries. This spray has been formulated to aid in the rapid and thorough removal of oils, greases, waxes and resin residues. Klüberfood NK1 Z 8-001 Spray is an organic solvent cleaning agent that is registered NSF K1 and K3, which helps promote safety in non-food processing areas.
Klüber Lubrication
www.klubersolutions.com
Speak Your Mind
