Allied Moulded Products Inc. is expanding its line of premium enclosure accessories with NEMA 4X ventilator kits for electrical enclosure applications.
The vent kits are designed to provide thermal cooling for instruments or electronics installed inside electrical enclosures plus rain-tight protection for the air flow passages through the enclosure walls. The vent kit features a strong and rigid design as they are molded of polycarbonate thermoplastic material and maintains a NEMA 4X seal with the use of a Formed-In-Place (FIP) polyurethane gasket system. They are well-suited for outdoor applications plus UL listed for use on a flat surface of NEMA 4X enclosures. The mounting procedure is relatively simple plus the internal baffle system ensures zero water infiltration when exposed to rain in outdoor applications.
“We are really excited about offering NEMA 4X vent kit accessories,” said Robert Knecht, Marketing & Product Manager. “This is a product that is needed for a multitude of applications in order to provide protection from water but also provide internal air flow cooling for the equipment housed inside.”
Allied Moulded continues to be a leading manufacturer of nonmetallic electrical enclosures and a “one-stop resource” where fiberglass and polycarbonate products can co-exist depending on the specific application characteristics and chemical compatibility requirements.
Allied Moulded
www.alliedmoulded.com
Filed Under: Cabinets • enclosures • control panels
