1600W Front-end Power Supplies
By Patrick Curran | December 6, 2010
San Diego, CA – TDK-Lambda has launched a new line 1600W front-end power supplies for use in distributed, hot-pluggable and redundant power systems. The HFE1600 series operate off a universal AC input of from 85 to 265VAC, with active PFC, and provides a well regulated DC output of 12V, 24V or 48V. Operating efficiencies of up to 92% are typical. With the 19-inch rack-mount enclosure as many as five (5) supplies can be paralleled with automatic load-sharing to provide up to 7600W of output power. A popular option is an integral MCU in each supply that allows for remote programming, monitoring and status reporting via an isolated I2C and PMBus interface. And, an “energy-saving” feature of the I2C/PMBus interface is that rack-mounted HFE1600 supplies can be individually turned on or off as the total system load demand varies over time (aka “load-shedding”).
TDK-Lambda-HFE1600 power supplies
Key applications for the HFE1600 series include data centers, wireless base stations, industrial automation, telecommunications, RF power amplifiers, network equipment, storage systems and distributed power architectures.
The HFE1600 supplies, each measuring only 1.61”H x 3.35”W x 11.8”L, can be used individually or as many as five (5) can be mounted in an 1U-high 19-inch rack enclosure to form a paralleled connected, load-sharing, hot-swap, N + M redundant 7.6kW power system. Should a fault occur each supply has an internal ORing MOSFET switch that will automatically disconnect it from the load and the other paralleled supplies. Plus, alarm signals and LED indicators are provided to indentify a faulty unit. For added power, up to two (2) rack-mounted enclosures can be parallel or series connected.
When employing the HFE600-S1U rack-mount enclosure the DC outputs and current-share lines of each plugged-in HFE1600 supply are automatically connected in parallel with the others. In this way, scalable and expandable power is easily achieved, even in the field. The rack assembly includes two sets of output bus bars, each of which are rated at 200 amps, for a total of 400 amps per rack.
And, for higher power applications, up to two (2) power racks containing up to ten (10) model HFE1600 supplies can be zero-stacked (no space required between racks) and connected in “parallel” to provide up to 15.2kW of total output power in a compact 2U vertical space. Likewise, up to two (2) rack-mounted sets with five (5) units each can be connected in “series” for higher voltage requirements at up to 15.2kW.
Each HFE1600 supply has two variable-speed cooling fans and can operate in tempera-tures ranging from -10°C to 70°C. The airflow is directed from the front of each unit to the rear where the I/O connector is located.
For system monitoring, in addition to the optional I2C/PMBus interface, opto-isolated signals are provided including DC-OK, AC-Fail and Over-Temperature. Front-panel mounted LED indicators provide a visual status for DC-OK and AC-OK conditions. A remote On/Off control is also standard, as well as remote-sense to compensate for voltage drops in the cables that connect the supply outputs to the load. Other standard features include single wire current-share and an auxiliary 12V/0.5A output that is diode ORed. Remote programming of the output voltage and current can be accomplished via the I2C and PMBus interface, or with an external 0-5V signal or a 1k ohm potentiometer.
The 19-inch rack mount enclosure is available with AC inlets via IEC320-C16 connectors or terminal blocks for each of the five (5) power module slots. All units in the HFE1600 Series are fully RoHS-compliant, carry the CE mark and meet UL/EN60950-1 safety specifications, as well as EN55022 and FCC level B EMC conducted specifications. The radiated EMC performance complies with Level A requirements.
TDK-Lambda
http://www.us.tdk-lambda.com/lp/products/hfe-series.htm
Filed Under: Factory automation, Terminal blocks, ELECTRONICS • ELECTRICAL
