Acopian announced the availability of a new family of programmable AC-DC power supplies. Featuring wide-adjust output voltages from 0V-5V to 0-135V and current capabilities up to 70A, the 1U format single output voltage power supplies offer 750W of output power. These rack and bench top modules notably provide high power density, low ripple and a user-friendly front panel.
Acopian’s programmable switching power supplies with wide-adjust output voltages are suitable for use in a broad range of ATE, OEM and laboratory applications such as component testing, semiconductor burn-in, test and measurement, RF Amplifiers, LED/laser testing, as well as a variety of electromagnetic and electromechanical applications.
The power supplies accommodate the universal AC input voltage of 95 to 265VAC, 50/60Hz with active power factor correction (PFC) of 0.99 single phase to ensure operation in challenging AC environments and compliance with European EMC requirements. For added support, models can be configured with an optional fixed auxiliary output of between 3.3Vdc and 125Vdc, up to 180W.
An intuitive front panel supports reliable linear controls for precise adjustment, and optional digital LED voltage and current meters. Voltage and current monitor outputs, and provisions for N+1 redundancy and paralleling for higher current, are also optionally available. Pluggable connectors are provided to facilitate quick and easy wiring of control and input leads.
Acopian
www.acopian.com
Filed Under: Cables + cable management, Connectors (electrical) • crimp technologies, Power Electronic Tips
