Acromag expands its line of ethernet remote I/O modules
By Mike Santora | August 17, 2022
Product Image of the NTE2620Acromag’s newest addition to the Busworks® NT Series of expandable remote Ethernet I/O modules is the NT2620 Series RTD/resistance module. Designed to be a cost-effective modular solution, it supports four RTD/resistance inputs and two bidirectional discrete digital I/O channels to monitor temperature limits with conditional logic. NTE Ethernet I/O models have dual RJ45 ports and a webserver with Modbus TCP/IP or EtherNet/IPTM communication to monitor or control the internal I/O channels.
The Modbus TCP/IP or EtherNet/IPTM communication is field-selectable saving costs of additional modules. An integrated DIN rail bus allows a connection of up to three NTX expansion I/O modules. The space-saving design requires only 25mm of DIN rail per module. Ethernet I/O modules distribute 9-32V DC power along the DIN rail bus to expansion modules. Hazardous location approvals, high noise immunity, and -40 to 70°C operation make this I/O ideal for use in harsh environments.
“Now Acromag can interface a wider variety of temperature sensors and offer discrete signals to monitor threshold levels or control alarms,” states Robert Greenfield, Acromag’s Business Development Manager.
Profinet communication is planned for release soon. Each module will support all three protocols which are selectable using any web browser to configure the network settings and I/O operation. The modules typically function as a network slave, but also offer Acromag’s i2o® peer-to-peer communication technology to transfer data between modules directly without a host or master in between. Multicast capability is included.
Acromag
www.acromag.com
Filed Under: I/O modules
Tagged With: acromag
