The ACT series current transducers come in split- and fixed-core models and have jumper-selectable current input ranges and industry standard 4-20 mA or 0-10 Vdc outputs. They are ideal for remote monitoring and software alarms. Split-core models make using portable data loggers easy, and simple connection enables power consumption or other motor status display.
The ACTR series current transducers comprise a current transformer and a True RMS signal conditioner in a single unit. They come with 4 to 20 mA output and use True RMS technology for accuracy on distorted waveforms. They monitor load operation via VFD outputs and give accurate measurement of phase angle fired or burst fired SCRs.
The AcuAMP series also includes current operated switches equipped with LED status indication. The ACS150 series current operated switches combine a current transformer, signal conditioner, and limit alarm into one package. They also come in split- and fixed-core models. They are ideal for monitoring proof of operation applications. The ACS150 has an adjustable set-point range of 1-150 amp and universal, solid-state outputs.
The ACS200 series current operated switch comes with three jumper-selectable input ranges for more flexibility, and more precision in set-point adjustment. Standard features include isolated solid-state relay outputs, multiple input ranges, and split- and fixed-core models.
The ACSX series high-performance current-operated switch has a 0.2 to 15 second field-adjustable time delay feature to minimize trips from high inrush or short overload conditions during start-up and operation. The switches are designed for motor status applications where set-point accuracy and repeatability are critical.
About Automation Direct
AutomationDirect sells over 6,000 feature-packed products through its Online Automation Superstore and 1,900-page catalog. The company offers its customers high-quality automation products, which are often priced below the industry average, 24-hour order entry and same-day shipping on in-stock items, outstanding sales and technical support, and a 30-day money-back guarantee on almost every product.
For a free catalog, access its Web site at www.automationdirect.com or call 800-633-0405.
AutomationDirect
3505 Hutchinson Rd.
Cumming, GA 30040
Tel: 770-889-2858
Fax: 770-889-7876
:: Design World ::
Filed Under: Factory automation, Mechanical, Motion control • motor controls, Switches
