    • Subscribe!
Advantech Launches PCI-104 Based Relay & Isolated Digital Input Card
By Dave Miyares | June 11, 2009
Cincinnati, OH — The Industrial Automation Group of Advantech introduces the PCM-3761I, a form C type eight channel relay and eight channel isolated digital input PCI-104 card for machine and production automation. The PCM-3761I’s relay allows operators to retain output values even in the event of an unexpected system reboot. The input channels support 2,500 VDC and a wide input range of 5 ~ 30V, allowing it to be resistant from surge or noise interference.
Moreover, the PCM-3761I provides a newer variation on the PC/104 standard, PCI-104, which is designed for embedded computing environments. PCI-104 is replacing the ISA bus, which is being phased out in the industry due to speed and compatibility issues with newer processors. PCI-104 is stackable and fast providing reliable anti-vibration functionality.
Advantech
www.advantech.com/ea
Filed Under: Factory automation, Computer boards, Electronics • electrical
molex-premo-flex
    • Subscribe!
