Developed with machine tool performance in mind, EVO 1 is a new approach to driving machine tool axes. The EVO 1 mechanical gearing system approaches the performance of a linear motor at the lower price of a rack and pinion linear axis. Features include high stiffness, zero-backlash, and an ultra-minimal transmission error. This new design provides vibration-free motion and an optimum surface finish for the machined part.
At the show, Andantex will showcase its first range of redesigned planetary reducers featuring EVO 1 technology — the SRP, KRP, KRPX, and DRP Series — which are all available in their existing sizes. The new design still features the breakthrough technologies that made this range of products a favorite for machine tool builders; small diameter integral output pinion, huge preloaded tapered roller output bearings helping to create maximum combined (radial, torsional and axial) stiffness, as well as Patented ZERO-BACKLASH DualDRIVE and TwinDRIVE solutions.
In addition to the planetary reducers, visitors can also check out many other products from Andantex’s varied
lineup, including:
-Linear and rotary axis drive systems.
-Two-speed spindle drive gearboxes.
-Automatic lubrication systems.
-Merobel magnetic particle tension control systems.
Andantex
www.andantex.com
Filed Under: Gears • gearheads • speed reducers
