    • Subscribe!
AutomationDirect releases white paper on electrical arcs
By Megan Hollis | October 14, 2015
AutomationDirect announces the release of a new White Paper, “Electrical Arcs”, that explains how arcing develops, the dangers of electrical arcs and various means of arc suppression.
Automation Direct
Common causes of electrical arcs include misapplication of components and dirt buildup. Over time, dirt builds up on electrical components, causing standoff voltages to decrease until an arc initiates. Then, either the arc energy blows the built-up dirt away and the component returns to normal operation, or the dirt burns, creating a carbon path on the insulating surfaces of the component(s), thereby permanently reducing the stand-off voltage. This reduction in stand-off voltage promotes more arcing, which causes more damage rapidly forming a run-away situation.
Electrical arcs not only present a hazard to equipment, but to personnel. This White Paper provides detailed information on how arcing happens and the various steps you can take for providing arc suppression.
The Electrical Arcs White Paper can be downloaded as a PDF at:
http://www.automationdirect.com/static/press/Electrical-Arcs-white-paper.pdf
AutomationDirect
Filed Under: Drives (ac) + VFDs + starters
Tagged With: automationdirect
Square_M-Factory-Drive-Recorder-SW-Product-Page-Image-565x520
Omron factory drive recorder
duodrive-logidrive-web-rgb
The LogiDrive System from NORD DRIVESYSTEMS
durapulse-gs10-product-image
DURApulse GS10 Micro AC Drives from AutomationDirect
Rockwell Automation introduces new on-machine drives
    • Subscribe!
