Although designed for use in conjunction with AVX’s new 2.5-mm no-wire-stop 70-9296 series STRIPT poke-home contact, the new 10-9296 Series BTB pin jumpers from AVX Corp. are drop-in compatible with competitors’ jumpers and offer a shortened insulator, a unique insulator geometry that achieves watertight connections, and the only ~38-mm pin length currently available.
This new series of pin jumpers is designed for board-to-board (BTB) and module-to-module connections in solid-state lighting (SSL) and other low-pin-count industrial applications. When used in conjunction with the new 2.5-mm 70-9296 Series STRIPT horizontal, poke-home contact without a wire stop — which is both the first industrial poke-home connector available without an integral wire stop and, currently, the only industrial poke-home connector with a 2.5 mm profile — the new 10-9296 Series BTB pin jumpers are allowed to pass straight through the contacts, completely unrestricted, until the final, user-defined mating dimension is achieved.
Unlike traditional BTB pin jumpers — which are made to mate with traditional connectors and are thus closed on the back end, limiting the depth to which a pin can travel and restricting the amount of BTB or module-to-module mating tolerance that the jumper can absorb — the new 10-9296 Series BTB pin jumper/709296001025016 contact combination absorbs the maximum amount of component and assembly tolerances during the mating process, effectively eliminating the PCB and housing tolerance stack-up issues common to traditional connector systems in linear and coplanar applications.
The new 10-9296 Series BTB pin jumpers are rated for 9 A, 300 Vac based on contact spacing, three-cycle durability, and operating temperatures spanning -40° to 105°C, and are currently available in two different pin lengths: 26 mm to support linear BTB connections and 38.15 mm to support linear module-to-module connections in which the contacts are embedded within plastic housings. Both variants have a standard 1 mm diameter pin that is mating-compatible with competitors’ traditional 4 mm-pitch poke-home connectors, as well as the company’s own 70-9296 Series 2.5 mm STRIPT contacts — but offer two clear advantages: a shortened insulator (just 5.1 mm) and a unique insulator geometry with dual-chamfered ends that provide a watertight connection when seated within a corresponding housing cavity.
“Our new 10-9296 Series BTB pin jumpers are very user- and application-friendly, enabling variable final mating positions for maximum tolerance absorption in SSL and other low-pin-count industrial applications when combined with our new no-wire-stop 2.5 mm 70-9296 Series STRIPT poke-home contacts,” said Tom Anderson, product manager at AVX. “They are also currently the only BTB jumper on the market to offer a 38.15 mm length.”
The new 10-9296 Series BTB pin jumpers have a glass-filled Nylon PA-66 insulator approved to UL94 V-0 and lead-free, tin-over-nickel-plated brass contacts. UL approval is in progress, and is expected this month. AVX is also currently sampling a two-position version of the BTB pin jumpers, and expects to announce production inventory by May.
For more information about AVX’s new 10-9296 Series BTB jumpers, please visit http://www.avx.com/products/connectors/board-to-board/coplanarlinear/btb-jumper-10-9296/. For immediate availability, please visit Future Electronics and TTI, Inc. For all other inquiries, please visit www.avx.com, email [email protected], like them on Facebook https://www.facebook.com/avxcorp/, follow them on Twitter https://twitter.com/avxcorp, call 864-967-2150, or write to One AVX Boulevard, Fountain Inn, S.C. 29644.
About AVX
AVX Corporation is a leading international manufacturer and supplier of advanced electronic components, interconnect, sensing, control, and antenna solutions with 29 manufacturing facilities in 16 countries around the world. AVX offers a broad range of devices including capacitors, resistors, filters, couplers, sensors, controls, circuit protection devices, connectors, and antennas. The company is publicly traded on the New York Stock Exchange (NYSE:AVX).
For more information, contact:
Tom Anderson
Connector Product Manager, AVX
843-241-2179
Christina Sandidge
Public Relations Specialist, BtB Marketing
919-872-8172
If you would rather not receive future communications from BtB Marketing Communications, let us know by clicking here.
BtB Marketing Communications, 900 Ridgefield Dr. Suite 135, Raleigh, NC 27609 United States
Filed Under: Capacitors
