Banner Expands EZ-LIGHT™ Indicators Line
By Patrick Curran | December 14, 2010
MINNEAPOLIS, MN — Banner Engineering Corp. introduces K50LD Daylight Visible lights to its line of EZ-LIGHT™ indicators. The 50 mm lights provide a solution for areas where high visibility is required, even in the presence of direct sunlight. The new indicators provide a controlled field of view for signage and narrow lane use, and may also be used for low-cost vision sensor illumination. Banner’s EZ-LIGHT™ K50LD Daylight Visible indicator lights are rugged thanks to their IEC IP67 rating, cost-effective because they are compact and completely self-contained which eliminates the need for a controller, and are easy-to-install with their 30 mm mounting base. Models may be ordered with either AC or DC supply voltage, and are immune to EMI and RFI interference. The DC models are available with up to three colors in a single housing, as well as PNP or NPN input type, depending on the model.
banner-ez-light
Banner Engineering
www.bannerengineering.com
Filed Under: Electronics • electrical, Lights • signal lamps • indicators
molex-premo-flex
