Battery Powered, Portable 20 GHz Synthesized Signal Generator Presented as Industry’s First
By atesmeh | April 27, 2010
Hittite Microwave has launched the HMC-T2100B battery powered, 10 MHz to 20 GHz Portable Synthesized Signal Generator. Designed to fulfill signal generation needs in the field or on the bench, the HMC-T2100B provides the highest output power, lowest harmonic levels and broadest frequency range compared with portable signal generators of similar size and cost, according to the company. Suitable for use in automated test and measurement environments, research, and development laboratories, this compact and lightweight frequency generator delivers up to +27 dBm of CW output power in 0.1 dB steps over a 40 dB dynamic range. Harmonic rejection is better than -39 dBc at 1 GHz, and spurious products are better than -65 dBc at 10 GHz. Phase noise is -113 dBc/Hz @ 100 kHz offset from 1 GHz with insignificant deviation over the temperature range of 0 to +35°C. The broad frequency range of 10 MHz to 20 GHz covers all major communication bands with frequency resolution of 10 kHz, 0.1 dB power resolution, and fast switching speed of 300 µs.
Hittite Microwave Corp.
978-250-3343, www.hittite.com
