Bel Power Solutions announced the expansion of their high power portfolio with the TXP4000 Series, a maximum 4000 W AC-DC power supply suitable for industrial, process and control, railway and machinery applications.
The TXP4000 Series of AC-DC converters employs a PFC front-end stage and an isolated DC-DC stage to convert the 3-phase input voltage to a low DC output voltage in a broad array of industrial applications where high efficiency is a requirement, with emphasis on both reliability and long product life. The TXP4000 Series also include DSP technologies, which enable monitoring of electrical parameters (including input voltage of all 3-phases) and allow control of the PSU from a system controller. RS485 / CAN bus communication is available to command, monitor and provide diagnostic information that can be used to interface with a system controller.
TXP4000 Series power supplies feature a compact footprint (135 x 85 x 465 mm / 5.31 x 3.35 x 18.31 inches) and accommodate the worldwide 3-phase input voltage range of 350-528 Vrms at up to 63 Hz, with active current share system available. Units can be used in parallel (8 units) or serial configurations (4 units), generating a maximum output power of 32 kW. The output voltage is adjustable, ranging from 30 V to 137.5 V optimized to 110 V, fully protected against overvoltage, overcurrent, overtemperature and short circuit situations. 12 V auxiliary output is also available. A highly efficient thermal design with an internal fan cooling system permits their use over a wide operating temperature range of -25° to +55°C.
For more information, visit belfuse.com/power-solutions
Filed Under: Converters (electrical) AD + DA • transformers
