TPC Wire & Cable Corp., Macedonia, Ohio, introduces a new product to its Chem-Gard family of cables. The Chem-Gard 200˚C CAT6 Industrial Ethernet Cable is a 100 Ohm category cable built to perform in the harshest industrial environments while delivering data communications at up to 250 MHz. Chem-Gard products have a specially designed fluoropolymer jacket and insulation engineered to stand up to corrosive chemicals, constant flexing and extreme cold and heat ranging from -60° up to 200°C.
In today’s industrial environments, taking precautions to avoid extreme temperature, oils and chemicals that come into contact with Ethernet cables can be an advantage in reducing unnecessary replacements and costly downtime. Without the proper protection, a cable’s jacket can swell, crack or harden after exposure to chemicals and can even wick the fluids into the cable itself. In addition to chemicals and extreme temperatures, Chem-Gard’s unique physical properties also offer resistance to UV light, cutting, abrasion, oil, impact and flame.
The Chem-Gard 200˚C CAT6 Industrial Ethernet Cable is perfect for industries whose environments can be unusually severe such as steel, automotive, wood, pulp and paper, transportation, food processing, oil and gas, utility, mining and government. The finely-stranded sliver-plated copper conductors allow for ultimate flexibility and a longer flex-life. The cable also provides superior performance to meet or exceed CAT6 and Ethernet/IP requirements.
“Many manufacturers run Ethernet cables through conduit or areas where it is exposed to extreme heat, abrasion and chemicals,” said Bill Root, TPC Wire & Cable Product Manager. “TPC not only designed its Chem-Gard products to provide excellent protection from these conditions, its fluoropolymer jacket also makes the product easy to pull through conduit, eliminating the need for compounds or lubricants.”
www.tpcwire.com
The post CAT6 Ethernet cable for industrial environments appeared first on Wire and Cable Tips.
Filed Under: Cables + cable management, Ethernet — cables • hubs • switches, Wire & Cable Tips
