Silicon Laboratories Inc. introduced what are said to be the industry’s smallest and lowest power customizable clock generators. Available in a 1.7 mm-squared package, Silicon Labs’ new Si512xx clock generator family offers up to 60 percent lower power than competing solutions, according to the company, and is appropriate for space-limited, cost-sensitive embedded and consumer electronics such as portable media players (PMPs), industrial metering and monitoring, portable navigation devices (PNDs), handsets, digital cameras and hundreds of other handheld, power-sensitive products. The Si512xx clocks are highly customizable devices. They support up to three LVCMOS clock outputs from 3 MHz to 200 MHz in a single device, providing developers with maximum flexibility while simplifying supply chain management. Each output has four levels of output strength setting, which can be configured individually to match the load and the trace length condition of the board. This is more than twice the configurability of the closest competing product.
The ultra-small Si512xx clocks typically use up to 80 percent less board space than competing clock generator ICs and provide cost-saving replacements for sub-200 MHz LVCMOS oscillators. By supporting multiple LVCMOS outputs, the single-chip Si512xx clock generators replace multiple surface-mounted crystals and oscillators with one economical device, further reducing board space and BOM cost.
In addition to unparalleled cost and space savings, these ultra-small clock generators also support green initiatives by reducing power consumption up to 60 percent compared to competing solutions. This 2x low-power advantage offers noteworthy benefits such as longer battery life in power-sensitive applications ranging from smart meters to handheld devices. The Si512xx clocks also provide output enable (OE) functionality to achieve even lower power modes in standby or sleep states.
The Si512xx clock generators provide customizable spread spectrum clocking technology to minimize electromagnetic interference (EMI). This frequency modulation technique enables system designers to reduce EMI by spreading clock energy over a wider frequency range, consequently reducing peak emissions at the fundamental frequency and every harmonic. The Si512xx further reduces EMI and increases system margin for data integrity through an innovative approach to edge-rate slew customization. The Si512xx clock family’s highly flexible architecture can be factory-customized to support specific spread spectrum and edge-rate slewing profiles, percentages, modulation types and/or rates to meet customer specifications for output frequencies, control inputs and drive strength.
877-444-3032, www.silabs.com
