Desktop Metal announced it has qualified commercially pure copper (> 99.95% purity) for additive manufacturing on the Production System platform, and its Single Pass Jetting (SPJ) technology. Customers can now leverage SPJ technology for the production of high-performance copper parts at scale across a variety of industries, including automotive, aerospace, and electronics.
With its excellent thermal and electrical conductivity, commercially pure copper is an ideal material for applications requiring heat or electricity transfer, such as cold plates, pucks and manifolds, heat sinks, heat exchangers, and bus bars used in power-intensive electrical applications. It is the third-most-consumed industrial metal in the world.
Desktop Metal’s materials science team has qualified and fully characterized commercially pure copper (C10300) printed on Production System technology. Manufacturers can now print copper parts on the Production System with significant geometric complexity in a single step instead of brazing multiple conventionally produced copper components together. With the geometric freedom enabled by binder jetting, engineers can also explore new, high-performance designs not possible with conventional manufacturing methods, such as the lattice structures and conformal cooling channels to improve heat transfer.
An example of a key application is a liquid cooling plate. Liquid cooling plates are used to regulate temperature on high-performance microprocessors. Coolant flows through the fins, which provide a large surface area to transfer heat from the passing fluid to the heat sink in order to cool the chip that is attached to the outer body. These cooling geometries typically require capital-intensive, long lead time, and skilled labor-intensive production processes, such as skiving and machining, given the challenges associated with achieving precision and repeatability in such a small form factor. In addition these commonly used conventional manufacturing processes are subtractive and produce excess scrap material, greatly increasing the associated part costs.
Whereas conventional production methods for this liquid cooling plate required machining and assembling multiple separate components due to restrictions on tool access, binder jetting on the Production System can produce the part as a single component, reducing manufacturing and operational complexity, part cost, and lead time. The Production System unlocks the capacity to print hundreds of cooling plates per day, enabling cost-effective volume production. Copper is the ideal material for heat exchangers due to its excellent conductivity, maximizing heat dissipation from the electronic chip to the cooling fluid.
The Production System platform consists of two printer models: the P-1, a solution for process development and serial production applications, and the P-50, a large form factor mass production solution for end-use parts. The Production System combines Desktop Metal engineered binders with an open material platform, allowing customers to produce high-performance parts using the same low-cost metal powders used in the Metal Injection Molding (MIM) industry. An inert processing environment enables compatibility with a variety of materials, including high-performance alloys and even reactive metals, such as aluminum and titanium.
In addition to copper, the materials library for the Production System platform has expanded to include D2 tool steel, 420 stainless steel, nickel alloy IN625, 4140 low-alloy steel, 316L stainless steel, and 17-4PH stainless steel, each of which have been qualified by Desktop Metal. The platform also supports several customer-qualified materials, including silver and gold, and Desktop Metal plans to add additional metals to its portfolio, including tool steels, stainless steels, superalloys, and more.
Desktop Metal
www.desktopmetal.com
Filed Under: Make Parts Fast
