Dual high-temperature Cabinet Cooler systems for large enclosures
By Lisa Eitel | June 13, 2022
EXAIR’s dual high-temperature Cabinet Cooler Systems purge and cool overheated electrical control panels in harsh environments up to 200°F (93°C). Cabinet Coolers keep electrical enclosures cool with air as cool as 20°F (-7°C) air to eliminate high temperature malfunctions and protect sensitive electronics from hot, dirty locations, such as foundries, glass plants or steel mills. The high cooling capacity up to 5,600 Btu/hr. is ideal for large electrical enclosures and high heat loads. Models with lower cooling capacities for NEMA 12, 4 and 4X enclosures are also available.
Cabinet Coolers incorporate a vortex tube that cools ordinary compressed air to cold air without the use of refrigerants. They mount through a standard electrical knockout while maintaining the NEMA 12, 4 or 4X rating of the enclosure. Systems with thermostat controls minimize compressed air use, keeping the enclosure at ± 2ºF of the temperature setting. An automatic drain filter separator ensures no moisture passes to the inside of the electrical enclosure. There are no moving parts to wear out.
Applications include variable frequency drives, programmable controllers, industrial computers, motor controls, microprocessors and robotics. EXAIR is offering a special right now on Cabinet Coolers. Learn more at exair.co/58-ccpromo.
You may also like:
  • EXAIR 3D model and CAD Library has more than 70…
  • pneuw455x255hr_LB2
    EXAIR Webinar Series: Break the cycle of replacing electric shop…
  • EXAIR-product-graphic
    EXAIR’s calculator simplifies Cabinet Cooler System selection
  • EXAIR EasySwitch wet and dry vacuum
  • EXAIR.com Improves Web Accessibility with ADA Compliance Features
Filed Under: Factory automation
Tagged With: exair
Lisa Eitel
Lisa Eitel has worked in the motion industry since 2001. Her areas of focus include motors, drives, motion control, power transmission, linear motion, and sensing and feedback technologies. She has a B.S. in Mechanical Engineering and is an inductee of Tau Beta Pi engineering honor society; a member of the Society of Women Engineers; and a judge for the FIRST Robotics Buckeye Regionals. Besides her motioncontroltips.com contributions, she also leads the production of the quarterly motion issues of Design World.
Solid-state relay characteristics and applications
