    • Subscribe!
Dual Point Mini Cooler from EXAIR cools small parts and tools
By Lisa Eitel | July 16, 2019
EXAIR’s new Mini Cooler with Dual Point Hose Kit provides a stream of 20°F (-7°C) cold air to prevent heat buildup, reduce downtime and increase productivity. It is effective on small machining operations to eliminate burning, melting, and heat related breakage. The dual point option allows the cold air outlet to be directed at two different spots when cooling larger diameter tools, cooling two separate points or opposite sides of a material or process. Single Point systems are also available.
The Mini Cooler incorporates a vortex tube that converts an ordinary supply of compressed air into cold air at 20°F (-7°C). Flexible tubing that holds its position is provided to direct the cold airflow. An adjustable magnetic base allows easy positioning. Durable stainless-steel construction and an absence of moving parts assures maintenance free operation.
The Mini Cooler is suitable for applications where liquid cooling can’t be used due to part contamination or cost. Tolerances, product finish and production rates can improve dramatically. In addition to preventing premature tool wear, the Mini Cooler is suitable for cooling sewing needles, blades, small tools and lens grinding. All Mini Coolers are CE complaint and operate at a quiet 76 dBA. Mini Cooler Systems with Dual Point Hose Kit, Swivel Magnetic Base, and Manual Drain Filter Separator (with Mounting Bracket) are $345. For more information, visit www.exair.com/58/dualmini.htm.
You may also like:
  • EXAIR Hot Tap Digital Flowmeters simplify installation
  • Heavy-duty HEPA vacuum from EXAIR for 30-gallon drums
  • Small internal mix spray nozzles — to coat, cool, treat,…
  • EXAIR offers high-capacity quality HEPA vacuum
  • Exair-HEPA-800sq-60K
    Vacuum chips directly into an open-top drum with no moving…
Filed Under: TECHNOLOGIES + PRODUCTS, Flanges • supports • mounts • brackets, Hose • wraps + sleeves, Tubing components
Tagged With: exair
Lisa Eitel
Lisa Eitel has worked in the motion industry since 2001. Her areas of focus include motors, drives, motion control, power transmission, linear motion, and sensing and feedback technologies. She has a B.S. in Mechanical Engineering and is an inductee of Tau Beta Pi engineering honor society; a member of the Society of Women Engineers; and a judge for the FIRST Robotics Buckeye Regionals. Besides her motioncontroltips.com contributions, she also leads the production of the quarterly motion issues of Design World.
Self-contained actuator for a variety of applications
okw
Multiple mounting options for modular enclosures
Bluetooth-enabled digital readout
PBC-linear-ball-circuits-graphic
PBC Linear launches miniature metric ball screw assemblies
    • Subscribe!
